Demon350 Posted November 29, 2003 Report Share Posted November 29, 2003 when you pull the choke out when ur running, and the shee dies down it means your running rich ? and lean if you go faster ? Quote Link to comment Share on other sites More sharing options...
Banchetta Posted November 29, 2003 Report Share Posted November 29, 2003 when you pull the choke out when ur running, and the shee dies down it means your running rich ? and lean if you go faster ? If you pull the choke after it warmed up, and it revs higher, then your pilots are lean..if it dies when warm and revs when cold, then your all good...if it dies when cold then your rich.... Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 1, 2003 Report Share Posted December 1, 2003 He's talking about wot Banchetta. I chatted with him about this the other day. Demon350... wot is wide open throttle. The choke is going to make it richer by pulling it. Keep this in mind and it will help you remeber what's the difference is. If you pull the choke at wot and it runs better, you are lean. If you pull the choke at wot and it runs worse then you are right on or rich. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted December 2, 2003 Report Share Posted December 2, 2003 Now don't I feel sheeeepish!!!! Quote Link to comment Share on other sites More sharing options...
