steeler2169 Posted August 28, 2015 Report Posted August 28, 2015 Just did full rebuild and added tors removal. Started to sync carbs at idle with sync tool and left side is at 6 and right side is at 1.5. I've replaced reed pedals also. I need help I'm really getting aggravated Quote
RollinRhino Posted August 28, 2015 Report Posted August 28, 2015 It could be an air leak from the reed block gasket. Have you sprayed carb cleaner while running near the gasket? If it changes idle speed you have a leak there. Quote
steeler2169 Posted August 28, 2015 Author Report Posted August 28, 2015 I just checked the tube going to the other carb it's not cracked. The choke mid way out is trying to go in by its self Quote
steeler2169 Posted August 28, 2015 Author Report Posted August 28, 2015 I'll go try it but I even put a very thin layer of permatex on both sides Quote
steeler2169 Posted August 28, 2015 Author Report Posted August 28, 2015 Not to go off topic but me and you rode together at hasten a few years ago Quote
steeler2169 Posted August 28, 2015 Author Report Posted August 28, 2015 Just sprayed around reed cage no change Quote
steeler2169 Posted August 28, 2015 Author Report Posted August 28, 2015 I forgot to mention it does get vacuum when I do throttle up a little Quote
RollinRhino Posted August 28, 2015 Report Posted August 28, 2015 I remember the ride. I no longer have the Shee, but I have a TRX450R now. What kind of kit did you use for the tors removal? Take pics of the carb area when you get a chance. I know some people don't evenly cut the idle bosses flat enough and if angled too much that too can cause a leak. Quote
steeler2169 Posted August 28, 2015 Author Report Posted August 28, 2015 You might be on to something there one side I didn't get get a warm a fuzzy about being filed down flat. I have the motion pro Quote
