2005she Posted August 26, 2015 Report Posted August 26, 2015 I have a some toomey silencers and they are in great shape but the tip is fried and you can buy new ones but I don't know how to remove them from the silencers need your HELP Quote
hoppedupandcutdown Posted August 27, 2015 Report Posted August 27, 2015 Therefore, you will need a large pair of snap ring pliers. Quote
trickedcarbine Posted August 27, 2015 Report Posted August 27, 2015 Large pair of snap ring pliers will do the trick. You will need to make sure you have a set of tips that have a nice angle. Also I will help to pull the bolt holding the silencer up. There's way more room once you lower it and aren't up on the grab bar. It may also help to use a flat head and a mallet to tap the snap ring a bit to loosen it it all the way around. That also helps to turn the snap ring if it's clocked to an impossible position. Quote
