2005she Posted August 25, 2015 Report Share Posted August 25, 2015 I just got a banshee and last owner only used it in the dunes but I will be mostly using it in trails and little in the dunes what is a good gearing for the trails Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted August 25, 2015 Report Share Posted August 25, 2015 I've tried a few different sprocket choices, always came back to the stock ratio. 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 25, 2015 Report Share Posted August 25, 2015 What mods are done to your bike currently? And when you are in the trails what gears to you find your self in? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 26, 2015 Report Share Posted August 26, 2015 Stock. I run 15/41 tho. Girlfriends bike is stock. I trail ride,open sand pits, jersey stuff. Quote Link to comment Share on other sites More sharing options...
2005she Posted August 26, 2015 Author Report Share Posted August 26, 2015 Motor is stock , mikuni carbs. K&n clamp on airfilters,vforce reeds ,t5 pipes and silencers,tors elimanator kit,and stock gearing right now going to change chain and wile I'm at it I may change gearing also Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 26, 2015 Report Share Posted August 26, 2015 Motor is stock , mikuni carbs. K&n clamp on airfilters,vforce reeds ,t5 pipes and silencers,tors elimanator kit,and stock gearing right now going to change chain and wile I'm at it I may change gearing alsoOk, so when riding which gears are you typically in? Are you looking for more acceleration, or do you have more open trails where you wanna be able to wind out top end? Quote Link to comment Share on other sites More sharing options...
mike0chek Posted August 26, 2015 Report Share Posted August 26, 2015 you will need some good power to run a 15 up front, i would try a 14/40 or something similar with your mods. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 26, 2015 Report Share Posted August 26, 2015 you will need some good power to run a 15 up front, i would try a 14/40 or something similar with your mods.^that. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted August 27, 2015 Report Share Posted August 27, 2015 (edited) Your bike sounds exactly like mine used to, I went with 15/40 gearing, still lots of power when you need it but you can stay in 3rd gear and cruise quite easily through trails not having to shift constantly. I'd recommend 15/40 or 14/40. Or not, your choice Edited August 27, 2015 by tdod101 Quote Link to comment Share on other sites More sharing options...
