-FB- Posted November 29, 2003 Report Share Posted November 29, 2003 hi guys. I got banshee with stock suspension. rear one became so smoth .. i tried to tight it up but still too smoth.. is there away to fix it? Quote Link to comment Share on other sites More sharing options...
Banchetta Posted November 29, 2003 Report Share Posted November 29, 2003 Too soft or too smooth.. You wan't smooth suspension...Adjust the rear spring to ride height.. you should pull the wheelie bar up until the suspension is all the way up and measure from the ground to the wheelie bar...now sit on it and have someone measure it again.. you should have around 2.5" of sag or difference in measurement....If it still rides too soft, then stiffen the compression knob on top of the shock... Quote Link to comment Share on other sites More sharing options...
