rustygold1 Posted August 24, 2015 Report Posted August 24, 2015 Looking for +4mm stroke long rod (115) ported cylinders to use with cut head. Or aftermarket full top end kit. Used or new! Comment and pm me ill consider anything Quote
Frankthetank Posted August 24, 2015 Report Posted August 24, 2015 I have a Redline built 4 mil long rod. Stock cylinders that are bored .20 over, dune port, race cut head from Lane, high flow water pump. On race gas, cams dyno read 80hp 46trq with stock carbs and cpi pipes. The trans is also cut and has new clutch basket with all mods done for smoother shifting. So, top end and bottom end for sale. asking $1600 plus shipping CPI pipes $400 small bore inframe with sparkys Quote
Strm Trpr Posted August 24, 2015 Report Posted August 24, 2015 Damn, ^^^ exactly what I'm going to build. Quote
rustygold1 Posted August 24, 2015 Author Report Posted August 24, 2015 I only need the cyls and maybe pistons the rest of my motors good but thanks for offer. I doubt u wana sell ur jugs alone Quote
dave5.0 Posted August 25, 2015 Report Posted August 25, 2015 I've got a set of nice resleeved to big bore jugs with a nice dune port job on them. Sitting at 65.5 mm now. Use blaster pistons. I've got a buddy spoken for them at the moment but if he doesn't want then they'll go up for sale. They ran good when I had them running. Quote
Frankthetank Posted August 25, 2015 Report Posted August 25, 2015 I would like to sell the motor whole. Quote
rustygold1 Posted August 25, 2015 Author Report Posted August 25, 2015 Dave, those jugs would work with stroker/long rod? Quote
dave5.0 Posted August 26, 2015 Report Posted August 26, 2015 Ya they are 4 mill, long rod, blaster piston cylinders. Quote
rustygold1 Posted August 26, 2015 Author Report Posted August 26, 2015 Set up fo spacer or cut head? Quote
slag_350300 Posted September 5, 2015 Report Posted September 5, 2015 I have a Redline built 4 mil long rod. Stock cylinders that are bored .20 over, dune port, race cut head from Lane, high flow water pump. On race gas, cams dyno read 80hp 46trq with stock carbs and cpi pipes. The trans is also cut and has new clutch basket with all mods done for smoother shifting. So, top end and bottom end for sale. asking $1600 plus shipping CPI pipes $400 small bore inframe with sparkys Is $1600 just for the cylinders, pistons and crank? Or the whole engine? Quote
