Running 300 mains I got t4 head pipes pro core silencers stocks carbs no air box and 65.5 bore and 30 pilots but it doesn't like to take throttle and takes it a sec to un-rev
You might want to do a leakdown test. I'm guessing when you say un-rev, you mean idle down. An airleak or too small pilot can cause this. I dont believe your pulot is too small at 30. To get carbs jetted properly, you need to eliminate any airleaks. Intakes are notorious for leaks.
  • Like 1
No sealant should be needed on stock gaskets and stock cylinders. Some people do put yamabond on then though. Aftermarket cylinders have more porosity and inconsistencies and may need sealant though.
No port work maybe next set of jugs I'll look for a air leak I copper sealed all the gaskets but Ya never know
That outlook will end up with a blown motor
I figured better safe than sorry with the copper seal
I was talking about the " I will check for air leaks when it's time for new jugs" part. Do a leak down and make sure it holds.
Check for air leaks , it's been very hard pressed for me to find good mating surfaces that don't need sealer , 8-10 yrs ago no problem lately everything I open up is haggered
  • Like 1
