sr73087 Posted September 18, 2016 Author Report Posted September 18, 2016 So I drove it around the yard again and there is definitely a clutch issue. It will shift just fine through the gears while off but while moving it is very difficult to shift. So I drained the oil and found a good amount of debris in the trans oil. Is this much junk normal in wet clutch atvs? It looked like mostly junk with small amounts of metal, I am hoping this is mainly clutch material? With that being said this is the 1st time I am draining the fully filed trans since owning it. Quote
RIPPIN' IT UP Posted September 19, 2016 Report Posted September 19, 2016 If there are no large chunks in there it should be right, having fine stuff is pretty normal, if there is a build up of fine, means either the oil has not been changed in a while or it in the early stages of something on its way out. Sent from my ZTE T84 using Tapatalk Quote
sr73087 Posted November 13, 2016 Author Report Posted November 13, 2016 Well I was able to get back to this project today and am adjusting my clutch after installing a new cable. I it for a few minutes to warm it up and then shut it down and drained the oil. The magnetic plug had a decent amount of crud on there, I noticed 1 big piece of debris. The oil looked grayish. What does clutch material typically look like? I am pretty concerned but hoping this could be crud that had to be flushed out......maybe just wishful thinking. Quote
bigweav81 Posted November 13, 2016 Report Posted November 13, 2016 Have a pic of the debris? Sent from my SM-S820L using Tapatalk Quote
m671054 Posted November 13, 2016 Report Posted November 13, 2016 Rather than guess and hope, why not tear it down and completely go through it. You had a minor air leak on the clutch side a year ago. Best case your out under $100 for gaskets,seals,and lock tabs plus you know exactly what you have. Quote
sr73087 Posted November 13, 2016 Author Report Posted November 13, 2016 Have a pic of the debris? Sent from my SM-S820L using Tapatalk Sorry this time I did not take a picture. Phone was inside charging. I'll snap I pic when I pull the clutch cover Rather than guess and hope, why not tear it down and completely go through it. You had a minor air leak on the clutch side a year ago. Best case your out under $100 for gaskets,seals,and lock tabs plus you know exactly what you have. Yea, you are probably correct. Is there a write up on here? I have the clymers either way. Quote
bigweav81 Posted November 13, 2016 Report Posted November 13, 2016 Yeah search bottom end walk thru bansheehq. Sent from my SM-S820L using Tapatalk Quote
guns4children Posted November 14, 2016 Report Posted November 14, 2016 Yeah search bottom end walk thru bansheehq. Sent from my SM-S820L using Tapatalk X2 that's a great write-up. I built my engine using that. 1 Quote
