building a trail shee cast or forged pistons
Not to be a dick but i wasnt asking if i should have crank welded or not. We all know it should be. If the funds pop up that i can afford to have the crank welded i will but as of right now its a no go.
Not to be a dick, but if you're going to cheap out on important shit maybe you should sell your banshee.
  • Like 1
50 bucks plus shipping to and from plus new seals upwards of 100 bucks...im not drag racing, with gobs of compression so therefore i dont see the reason to weld the crank at this time.
You're clearly ahead of the curve and know exactly what your doing. You'll be fine. Run it.
I just see money being thrown down the tubes on a top end , did you pressure test motor before tear down to verify seals are good and pin point reason for failure. Banshees get a bad wrap because 99% of owners fail in proper procedure on teardown and assembly. Where do u live I would be willing to point you in the rite directions.
simple  forged.
100% stock replacement i'd say cast should be fine.  one thing cast will usually NOT wear the bore as much as a forged piston.  if the motor stays together and you do wear out a set of rings/ pistons  sometimes the bore is still true enough to drop in a set of fresh cast.   sometimes  not every time. piston to wall clearance is much more important on cast also.  to tight even a lil bit that sucker is going to cold sieze,  too loose even a smidge  that skirt is blowing out the pipes.
i didnt read all the other posts on this q..
Cast pro x in the girls bike.
Ported stock stroke that she'll rev the piss out of (as much as the pipes let her)
And that I ride like I stole it. No problems after a year. Pistons on hand for the boring process and obviously guy knew it was for cast.
Not a dealership that'll just bore to whatever size then go to the back and grab you Pistons.
