hello guys,
did someone have problems with a new set of DMC 916 pipes?
my friend ordered a new set of 916´s from ebay. he installed it an changed the jets in his stock carbs.
after some kilometers riding the left pipe was overheating the pipes is change the color. now its complete yellow due the silencer.
does someone know of mistakes in the production?
some facts about his shee:
motor stock
carbs stock
kn pod filter
jetting via EGT - temps on half throttle 350-400°C (left more than right)  wide open throttle 600°c on both jugs
thanks for help.
I have the exact same problem. Mine have gone yellow and have melted the shit out of the exhaust collars too. Bluejob works well to remove the yellow but the actual problem has not be solved yet. I run a 300 main middle clip.
my friend uses this adjustment:
mains 280
pilots  30
needle clip in the middle
air adj. screw 1-1 1/2 turns out.
plugs are lttlebit dark, but the plugbase is dry.
the right piston has some blowby, the left is looking new.
i drive his shee an it runs very well, bottom end is not so high like mine, but ok...
Edited by Robert80
did dmc a other material of the plating on the pipes?
i remenber that the pipes were sold out for a long time and dmc did a new prodution?
eventually the plating is really shitty, than  i am happy, that i have a old version.
Mine are still mint after a few seasons.....clues, thinkins n learnins.... :whistling:
Da fugg? Thought you had rockets.
Just put 916s on son's still lean with 300 M.
Had rockets, sold them a few summers ago....
  • 2 weeks later...
