Pushrod/ball weilded
Just had the same thing happen.(just putting mine back together)  your actuator wont come out because the push rod has mushroomed at the end and is blocking the actuator from coming out ....sorry to say but ur gonna have to pull it out and split the cases ..That's the only way to get that rod out. YES PUT THE PANCAKE BEARING IN !  My bearing was welded to the adjuster and the rod was mushroomed and welded to the actuator.  Not sure how u did yours but I let someone ride mine that did not know how to ride a clutch and shift gears properly so he either didn't shift at all or held the clutch in all the time and it seized it.   Good luck !
  • 2 weeks later...
