hoppedupandcutdown Posted August 10, 2015 Report Share Posted August 10, 2015 fiber in first and a fiber in last? Quote Link to comment Share on other sites More sharing options...
03banshee88 Posted August 10, 2015 Author Report Share Posted August 10, 2015 Yup Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
03banshee88 Posted August 10, 2015 Author Report Share Posted August 10, 2015 Only thing I did notice but don't know if that's what going to do that is one of the o rings that goes in under the fiber was broken but the little piece that was broken still went in under the fiber Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 10, 2015 Report Share Posted August 10, 2015 first, take all those o-rings out and throw them away. Second, when you're taking it apart double check the spline engagement cause from your video the plate is way to far out. But that could be from orings in between your fibers and steels Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 10, 2015 Report Share Posted August 10, 2015 I had the arrow on the pressure plate lined up with arrow on inner hub Sent from my iPhone using Tapatalk Then you need to figure out the adjuster on the end of the clutch push rod and ball. Quote Link to comment Share on other sites More sharing options...
