Bennett131 Posted August 7, 2015 Report Share Posted August 7, 2015 I figured maybe someone that drag races with a cub would comment...sheerider zilla, and myself don't have cubs. I would try dropping 2 teeth on the front. Front sprockets are cheap. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 7, 2015 Report Share Posted August 7, 2015 I think you need to grasp the concept of drag racing a little better. Maybe your slow out of the hole. Maybe wheel spin. Maybe clutch slip. Maybe over geared. There's literally thousands of things that can be wrong. Top speed doesn't make faster ET 1 Quote Link to comment Share on other sites More sharing options...
Atlbanshee Posted August 7, 2015 Author Report Share Posted August 7, 2015 I had a 17 tooth in front before and i run out of gears half way the track . So if I come slow out the hole that will make my top speed lower ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 7, 2015 Report Share Posted August 7, 2015 I had a 17 tooth in front before and i run out of gears half way the track . So if I come slow out the hole that will make my top speed lower ? Sent from my iPhone using Tapatalk Does the guy with the fastest mph win? Or the fastest et? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 7, 2015 Report Share Posted August 7, 2015 Forget mph for now what is your 60ft . If your not in the Lo lo 1.4,1.3 area your not effectively pulling that gear. What kind of clutch tuning are u doing. And Zilla your calculations are off on real world numbers last time at the track with an hq member that has never ridden asphault my bike hit 108 with 16/41 and it's went faster with me on it Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 7, 2015 Report Share Posted August 7, 2015 You should come on my pit crew lol could use a guy like you, I have custom primaries and my tires def swell Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 7, 2015 Report Share Posted August 7, 2015 I also go over 10k with overevs Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted August 7, 2015 Report Share Posted August 7, 2015 I still think the op is off on his gearing compared to my experience Quote Link to comment Share on other sites More sharing options...
Atlbanshee Posted August 8, 2015 Author Report Share Posted August 8, 2015 I think my power jets on my carbs are little bit off. Also need more tuning carbs. Yesterday run better but no time on the track i was Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Atlbanshee Posted August 8, 2015 Author Report Share Posted August 8, 2015 Sound good let me find one and post it here Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Atlbanshee Posted August 10, 2015 Author Report Share Posted August 10, 2015 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
