What To Check (pre Ride Inspection)
What should I check for safety every time I ride?
Tire pressure, chain/sprockets, brakes, suspension, tie rod ends, controls, etc.
Also what kind of prevenitive matience should I do?
Change oil often, change plugs and bring some, keep a clean, oiled air filter, keep the bike clean
What kind of grease do you use in a grease gun to lube the a arms and rear swig arm (threw the grease fitting that you put the gun on)
Yamaha says to use white lithium grease
