Silverlake Posted August 3, 2015 Report Posted August 3, 2015 Just changed my jetting before heading up to silverlake, stock banshee mikuni 26mm carbs, fmf fatty pipes and silencers, v force 3 reeds, stock airbox and lid, have 270 mains, stock pilots and needle clip in middle position. For whatever reason i couldnt spin the paddles from a stand still if my life depended on it while i was in the dunes, 8 paddle skat trak haulers, I tried dumping the clutch and it still bogged down and wouldnt spin the tires quicky at all. Does anyone know whats going on? Quote
Silverlake Posted August 3, 2015 Author Report Posted August 3, 2015 Aswell I checked the new plugs that I put in and theyre nice and golden brown on the lower part of the electrode ( further away from the ground) Quote
lil Doobie420 Posted August 3, 2015 Report Posted August 3, 2015 Compression and leak down test. Also what paddles and gearing are u running Quote
Silverlake Posted August 3, 2015 Author Report Posted August 3, 2015 Skat trak 8 paddle, and gearing im not too sure on, i think 15 or 14 in the front and no clue on rear Quote
Silverlake Posted August 4, 2015 Author Report Posted August 4, 2015 Yeah i feel a lack of power in the bottom end, mid range and top are good and the bottom end just falls on its face Quote
Strm Trpr Posted August 4, 2015 Report Posted August 4, 2015 FMF pipes like 30 pilots. Do a leak down test too. Quote
Nightmare Posted August 4, 2015 Report Posted August 4, 2015 FMF pipes like 30 pilots. Do a leak down test too. Not in all cases. My old turd had fmfs and 30 was too big. 27.5 was about perfect. Elevation plays a big part. Quote
Strm Trpr Posted August 4, 2015 Report Posted August 4, 2015 Not in all cases. My old turd had fmfs and 30 was too big. 27.5 was about perfect. Elevation plays a big part. Not sure why you felt the need to say ^^^. He's running stock pilots with FMF's and VF3's FFS!!!! He at least needs 27.5 pilots. Just changed my jetting before heading up to silverlake, stock banshee mikuni 26mm carbs, fmf fatty pipes and silencers, v force 3 reeds, stock airbox and lid, have 270 mains, stock pilots and needle clip in middle position. For whatever reason i couldnt spin the paddles from a stand still if my life depended on it while i was in the dunes, 8 paddle skat trak haulers, I tried dumping the clutch and it still bogged down and wouldnt spin the tires quicky at all. Does anyone know whats going on? OP, seat the airscrews gently and see if it has more grunt. If so, then you need a bigger pilot, period, end of discussion. Quote
sick421 Posted August 7, 2015 Report Posted August 7, 2015 You are lean , try 30 pilots and 280 to 300 mains Sent from my iPhone using Tapatalk Quote
