Finally throwing on my new carbs. Wanted to get some help with a baseline of where to start at with jetting.
My shee is a 97 and usually ride glamis and trails. Never more than 1000' ASL
One over stock bore (true 350 now)
Dune port
VF3
+4 timing
19cc domes
FMF fatties
Run a mix of race and pump equalling 100 octane. And run 32:1
Switching from a BS 2-to-1 carb setup. 2 in 1 was there for so long that I'm pretty sure I forgot how to mount up duals. So if I have some Qs, I'll post pics and all help is greatly appreciated. Thanks yet again for the help BHQ!
Edited by Dunatic619
Make sure u pressure test your motor before running it saves a lot of headaches . Surf is in the ballpark depending on porting styles , my porting likes bigger pilots some others don't depending on tunnel volume
42 ish on mild port , 45 w needle in 4th position , 48 heavily dune port , sleeper06 motors 50s all day lol . Jjh needles work best with there carbs. Just make sure you have a matched set and both slide numbers are the same.
421 serval on 28s: 142m 52p 4th pos JJH, 3/4 turns out.
Sent from my SM-G900V using Tapatalk
Well... This jetting turned into a 4ml build. Damn it. Still using my 28s though. Old shop that did my porting took it too far down and it seemed to be more of a drag port. I never wanted that. I also was pretty sure the crank wasn't trued up. I didn't want to chance it on a drag-Ish ported bike. So... I'm Getting a killer deal on fresh bored jugs (64.50), an aggressive mx port, matching case port, and a 4ml HR crank. Now it looks like I have to ditch the fmfs to really make it a beast. My builder said he's never really seen fmf do over 65 HP. also switching to pump gas domes. Tired of spending $10/gal for race. Hoping once the pipes are on that I'll have much better torque and shooting for 75 hp. Which my builder is very confident it will be. He was thinking on race gas, it could be in the low to mid 80s. But what's the point of running race when the fmfs will choke it back anyway. I can always switch domes later.
