Ignition Issues - where to look
I've suspected for a while now that I have a bad ignition (meaning the thingy the key goes into).
The other day, I had just started riding when, while going up a hill mid-throttle, my engine just cut-off and I came to a stop.
Tried to kick it several times, and could tell I wasn't getting any spark.
I turned ignition key off, and back on... kicked it once and she fired right up. No more problem for the next 2 hours of riding.
Sometimes I can't start the banshee on the first few kicks, so I'll turn ignition off/on and she'll start right up.
What should I check/replace to fix this issue?
If you want the key just buy a new switch and key assembly, if you dont care if you have a key or not, follow the harness from the switch, goes to a white 2 wire plug and splice the wires together. I think they are black and black/red stripped, but its been a while so I cant remember the colors for sure
