pablopab50 Posted July 28, 2015 Report Posted July 28, 2015 I currently have FMF SST pipes and looking to get either CPI Small bore inframes or Sniper Assasin inframes. My mods: .30 milled head, +4 timing, V-Force 4, air box lid removed, 160 PSI ground sea level Will CPI or Sniper outperform FMF SST with my actual 65.25 unported cylinders? I will probably go for a 421 when I'll have more money. I'm just thinking about buying some mandatory 421 cub parts such as carbs and pipes that could work with my stock cylinder. Could I run the 421 cub with 28mm PWKs? Thanks Quote
trickedcarbine Posted July 28, 2015 Report Posted July 28, 2015 For now I'd say go CPI, they will give you room to improve your current set up and be ok on a 421 later. You will see a pretty substantial gain without sacrificing much bottom end feel. Start doing work to the motor and they only get better. The snipers IMO would be great on a 421 I fact better then the CPI, but I don't think you currently have enough motor as is to make them shine. Quote
sleeper06 Posted July 28, 2015 Report Posted July 28, 2015 No but they will still outperform sst , I've put snipers on a few mild bikes . Quote
AxesOfEvil_96 Posted July 29, 2015 Report Posted July 29, 2015 (edited) I personally love my SST pipes for trail riding but CPI's & Snipers will out perform the FMF setup. 28mm pwk carbs are awesome on stock cyl bike. You would probably want to run a 33pwk or bigger for the 421. But I wouldn't go bigger then a 33 on stock cyl. You also might want to consider Shearer pipes too. They flat out rip Edited July 29, 2015 by AxesOfEvil_96 Quote
pablopab50 Posted July 30, 2015 Author Report Posted July 30, 2015 I talked to many builders and they all recommended 35mm PWKs. Now for pipes the choice remains mine but the damn Assasins are built on order only and his estimated labor time is about 5 to 6 weeks. I really want some of these but I'm trying to have a kind of trail sleeper 421. No pods. I'll keep the cylinder dry and my filter less dirty with the airbox. Problem is fitment. I asked him if he could make some for the airbox but I'd still have to trim the airbox a bit in order to mount the silencer tubes. By the way, does anyone know someone who has some that fits my needs? Quote
jbooker82 Posted July 30, 2015 Report Posted July 30, 2015 Trail Sleeper with in frame drag pipes. Quote
sheerider11 Posted July 30, 2015 Report Posted July 30, 2015 Trail Sleeper with in frame drag pipes.With CP cylinders and 35pwk. Sleeper. Quote
sleeper06 Posted July 31, 2015 Report Posted July 31, 2015 I've made custom bent snipers before for a Yfz , they are by far the easiest to bend stingers for with double slip fit o ring design . He sent me unbent pipe he uses and expansion chambers not welded together I'm sure he'll work with you . On the other hand I know shearer will bend them for you. I specialize in sleeper performance Quote
