Banshee_82 Posted July 28, 2015 Report Share Posted July 28, 2015 I got a 99 banshee that is not getting gas to the heads. I checked the tank screens, jets and choke cross tube. When I put some gas in the spark plug holes it's starts right up and dies when the gas in them are gone. Then I will go to kick it and will not start. Any ideas on the problem? Quote Link to comment Share on other sites More sharing options...
special06shee Posted July 28, 2015 Report Share Posted July 28, 2015 Needle and seat seized/stuck. Float height Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 28, 2015 Report Share Posted July 28, 2015 do a compression test Quote Link to comment Share on other sites More sharing options...
Banshee_82 Posted July 28, 2015 Author Report Share Posted July 28, 2015 I'll have get a compression tester. It's not getting any gas to the cylinders because they are dry. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 28, 2015 Report Share Posted July 28, 2015 Verify fuel flow from petcock, if it's no bueno you'll need to take it apart and freshen it up. Clean carbs properly and blow all jet passages with clean dry compressed air. Check needle & seat action as well as float height. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 28, 2015 Report Share Posted July 28, 2015 low compression = low vacuum = little or no gas at low RPMs also clogged pilot jets = little or no fuel at low RPMs also bad reeds = all sorts of problems Check the compression, at least pour some premix oil in the plug holes and see if it fires. since it is not combustible it will seal the rings and raise the compression and start if you got fuel, since you checked the jets already. Quote Link to comment Share on other sites More sharing options...
Banshee_82 Posted July 29, 2015 Author Report Share Posted July 29, 2015 Put gas in the holes and it starts good, then only stays running for 2-5 seconds. Cleaned pilot and main jets. Tank screens are clear. It's not getting gas into the cylinders and won't start in I put quick start through them. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 29, 2015 Report Share Posted July 29, 2015 Put gas in the holes and it starts good, then only stays running for 2-5 seconds. Cleaned pilot and main jets. Tank screens are clear. It's not getting gas into the cylinders and won't start in I put quick start through them.Can you just listen and check the compression.It's a 5 minute test. Can cause all the symptoms you're describing. This is the last thing to do before you pull the intakes and check the reeds. Quote Link to comment Share on other sites More sharing options...
Banshee_82 Posted July 29, 2015 Author Report Share Posted July 29, 2015 I'll have to go out and get a compression tester tomorrow then or ask my buddies if they got one. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 29, 2015 Report Share Posted July 29, 2015 won't start in I put quick start through them. Does that mean starting fluid, as in ether? Quote Link to comment Share on other sites More sharing options...
Banshee_82 Posted July 29, 2015 Author Report Share Posted July 29, 2015 Yes Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 29, 2015 Report Share Posted July 29, 2015 That is really bad. Quote Link to comment Share on other sites More sharing options...
Banshee_82 Posted July 29, 2015 Author Report Share Posted July 29, 2015 I'm picking up a compression tester right now Quote Link to comment Share on other sites More sharing options...
Motooutcastxxx Posted July 29, 2015 Report Share Posted July 29, 2015 Put gas in the holes and it starts good, then only stays running for 2-5 seconds. Cleaned pilot and main jets. Tank screens are clear. It's not getting gas into the cylinders and won't start in I put quick start through them. You cleaned the pilot and main jets but did you take care of... Needle and seat seized/stuck. Float height This ^^ too? Many times it takes a bit more than just a douching of carb cleaner to get all the crap off the "seats," so if your compression checks out pull the floats/float valves(needles) off, grab yourself a few q-tips, massage each seat with something like toothpaste (not the gel the actual paste) which works very well, once nice and shiny hit it with carb cleaner to get the rest of the shit out of there, good as new. Last time I did it I used a hair of Master Formula on a q-tip and polished them right up. Not sure it was the best idea but they worked just fine when I was done. Definitely make sure float height is adjusted to spec too, also extremely important. If you don't have one get yourself a service manual, lots of valuable info in there. I think there's one in the technical section you can download... Quote Link to comment Share on other sites More sharing options...
Banshee_82 Posted July 29, 2015 Author Report Share Posted July 29, 2015 Only 100psi in each cylinder. Needs top end. Would that cause it from not starting Quote Link to comment Share on other sites More sharing options...
