clutch actuator arm seized
Well guys just looking for your experience. Created the problem myself by allowing an inexperienced rider ride the shee. (wont happen again)  besides the point.  clutch actuator arm is seized in the open position as if you were pulling the clutch lever.What is everyone thoughs?  clutch plates melted together ? ball welded to rod ? before I rip it apart tonight just looking for some opinions.
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
nope will not budge to the left or right (as if u were pulling the clutch lever) or up or down.  it should jus pull right out.  The person that did it held it in first gear to the bar........this is the result. ive never seen it but could the push rod be welded to the actuator arm ?
I've herd this can be done upside down ????....is this a banshee myth or any truth to it ?
I've had good luck splitting the cases right side up, just use a ratchet strap around the crank ends up over the head, holds the crank up and you can put it back together and not fight the upside down trans problem.
