ImSoBoard1 Posted July 26, 2015 Report Share Posted July 26, 2015 I'm getting a timing plate installed. How much do you think a shop will charge to purchase and install one? I will also have it rejetted. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted July 26, 2015 Report Share Posted July 26, 2015 Don't pay a shop to do that... it is such an easy task. Curious what they charge you. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted July 26, 2015 Report Share Posted July 26, 2015 There is lots of video about the timing plate on yt. Quote Link to comment Share on other sites More sharing options...
oldskool Posted July 26, 2015 Report Share Posted July 26, 2015 Order you a mattoon, very easy to install if you have a flywheel puller. Must have the puller! Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted July 26, 2015 Report Share Posted July 26, 2015 Order you a mattoon, very easy to install if you have a flywheel puller. Must have the puller!This^^^^ For what you'd probably pay a shop,you could buy them plate and tools needed. Then you'll always have the tool for any future use. Sent from my SM-G900R4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted July 26, 2015 Report Share Posted July 26, 2015 Figure most shop rate are $75 per hour, so at least $75+ the $50 timing plate (if they don't charge $70 for it). Or for less than $20 you could buy a flywheel puller, $50 timing plate and be done in under a hour of your own time. Quote Link to comment Share on other sites More sharing options...
ImSoBoard1 Posted July 27, 2015 Author Report Share Posted July 27, 2015 ok ill do it myself Quote Link to comment Share on other sites More sharing options...
ImSoBoard1 Posted July 27, 2015 Author Report Share Posted July 27, 2015 wouldn't i need to rejet? Quote Link to comment Share on other sites More sharing options...
ImSoBoard1 Posted July 27, 2015 Author Report Share Posted July 27, 2015 fyi I've never played with carbs or tuned anything to extensively so more than likely i might be referring to the wrong part. Quote Link to comment Share on other sites More sharing options...
Dunatic619 Posted July 28, 2015 Report Share Posted July 28, 2015 Google the part and make sure it's the same part you're referring to. Once you're sure about the part, post pics on here and they'll walk you through it. Quote Link to comment Share on other sites More sharing options...
camp0429 Posted July 28, 2015 Report Share Posted July 28, 2015 http://bansheehq.com/forums/index.php?showtopic=137560 Quote Link to comment Share on other sites More sharing options...
