Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 (edited) I Edited August 1, 2015 by Mandolezama Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 I have good compression getting 150 in each cylinder Quote Link to comment Share on other sites More sharing options...
zillakilla02 Posted August 1, 2015 Report Share Posted August 1, 2015 Choke tube installed? Not cracked? Sent from my SAMSUNG-SM-G870A using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 Yea I put a new tube on it just to make sure Quote Link to comment Share on other sites More sharing options...
zillakilla02 Posted August 1, 2015 Report Share Posted August 1, 2015 You should leakdown test it and make sure you aren't sucking too much air from somewhere else. Float levels set right? Mine would start hard when my float levels were off Sent from my SAMSUNG-SM-G870A using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted August 1, 2015 Report Share Posted August 1, 2015 Sounds like an intake air leak Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 I haven't did a leak down test but when I tried my friends carbs on it, it started right up like one or two kicks so I'm thinking it something with my carbs Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted August 1, 2015 Report Share Posted August 1, 2015 Do a leakdown before you do ANYTHING else Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 Ok I will do a leak down test sometime this week. Also when I changed my pilot jets I noticed a nettle tube on the bottom of one of the carbs is missing not sure if that's a problem Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted August 1, 2015 Report Share Posted August 1, 2015 Overflow tube Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 Ok so nothing that will cause a problem then? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Doug Austin Posted August 2, 2015 Report Share Posted August 2, 2015 Sounds like the float bowls are swapped. There is a left and right bowl. In the bottom of each bowl is a small well. The left bowl has a small jet in the bottom the right does not. This supplys extra fuel when you pull the choke lever. If there backwards you have no choke. Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 2, 2015 Author Report Share Posted August 2, 2015 Ok thanks for all the help everyone I just did a leak down test and before it got to 6psi I could hear air leaking from the reeds gasket where it bolts to the cylinder. I will check the float bowls and replace the gasket and update after I do Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 2, 2015 Author Report Share Posted August 2, 2015 Ok so I replaced the reed gaskets and replace to clamps to the cross over and leak down tested it again and it held 6psi for longer than 30 min without dropping. Now it's starts right up just have to adjust the carbs now to get them to idle Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted August 10, 2015 Report Share Posted August 10, 2015 Awesome! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
