Mandolezama Posted July 26, 2015 Report Share Posted July 26, 2015 My banshee is hard to start but if I take off the air filter and cover the carbs to get fuel in the carb starts right up Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 26, 2015 Report Share Posted July 26, 2015 What size pilots you have? Quote Link to comment Share on other sites More sharing options...
oldskool Posted July 26, 2015 Report Share Posted July 26, 2015 Did this problem just begin with no changes to bike from you? If so, clean carbs,set floats and pay special attention to pilot jets/size Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted July 26, 2015 Author Report Share Posted July 26, 2015 The bike wasn't working when I got it had a bad stator I fixed it and now only this. It has Athena 392 big bore kit and bills pipes with stock carbs and reeds. Not sure what size pilot jets or any jets are in it Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted July 26, 2015 Report Share Posted July 26, 2015 Had 27.5 and wouldn't start if sat for few days. Now with 30s starts anytime. Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted July 26, 2015 Author Report Share Posted July 26, 2015 Ok so I will replace my pilot jets with bigger ones. Should I worry about the main jets if it runs great once it gets started. And also what size pilot should I use. Thanks for all the help Quote Link to comment Share on other sites More sharing options...
oldskool Posted July 27, 2015 Report Share Posted July 27, 2015 Clean carbs thoroughly, see what size pilot you have. you want to go up one size at a time OR clean the ones you have if they have been changed to a 27.5 or 30. Stock pilot is 25. You need to see what size main is also. Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted July 27, 2015 Author Report Share Posted July 27, 2015 Ok so I pulled off my carbs and my pilot jet is 25 which I assume is stock and my my main jet says AB320 on it so I'm guessing it's a 320. So should I go with a 27.5 or 30? Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted July 27, 2015 Author Report Share Posted July 27, 2015 Or should I go with something bigger than 30? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 28, 2015 Report Share Posted July 28, 2015 you want to go up one size at a time. Stock pilot is 25. This, still. Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted July 28, 2015 Author Report Share Posted July 28, 2015 Ok just ordered some will update when they get here and installed thanks for all the help Quote Link to comment Share on other sites More sharing options...
frankgurule1978 Posted July 28, 2015 Report Share Posted July 28, 2015 My banshee was running good when I wreck it only one cylinder is working how do I fix it Sent from my Z813 using Tapatalk Quote Link to comment Share on other sites More sharing options...
oldskool Posted July 28, 2015 Report Share Posted July 28, 2015 My banshee was running good when I wreck it only one cylinder is working how do I fix it Sent from my Z813 using Tapatalk Well first you have to start your own thread. Welcome to BHQ Quote Link to comment Share on other sites More sharing options...
frankgurule1978 Posted July 29, 2015 Report Share Posted July 29, 2015 Well first you have to start your own thread. Welcome to BHQ How do i do that im new to all this new tech i been locked up for a long time someone wouldnt mind helping a brother out how to get my important question answered Sent from my Z813 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mandolezama Posted August 1, 2015 Author Report Share Posted August 1, 2015 Ok I changed my pilot with a 30 and still have the same problem. When I first start it after sitting a day it won't start unless I cover the carbs and kick it a few times then it will start right up and run great. Once I start it it idles good and runs good. Need help what could it be Quote Link to comment Share on other sites More sharing options...
