So if there are any of you out there that are ocd about oil dripping out your exhuast onto your cylinders under high rpm. i have a solution find some tight fitting flat rubber washers and put them inbetween the exhaust and the cylinder and no more leaks a super tight fit. i did also look into bigger o ring inside the pipe but after trying a few different sizes the ones that would have worked were to dam tight and i could not get the exhuast back on without oring coming out of groove
