bluebanshee7 Posted July 23, 2015 Report Share Posted July 23, 2015 (edited) Clutch not engaging*** Rebuilt my shee and finally got it running right. Been trying to get though the break in process and something new keeps popping up. Was riding my shee in 1st and 2nd gear and was shifting fine...waited 2 hours now my clutch lever is completely flopping around. It still pulls the cable but with no tension at all. Everything on the outside looks right...could it be the clucth adjusting screw inside the clutch case came loose from riding it?? Any ideas would be great Thanks Edited July 23, 2015 by bluebanshee7 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 24, 2015 Report Share Posted July 24, 2015 Check the adjuster on the pressure plate, also look at the pressure plate and verify that it is clocked properly. Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted July 24, 2015 Author Report Share Posted July 24, 2015 Check the adjuster on the pressure plate, also look at the pressure plate and verify that it is clocked properly. It was my clutch adjuster...is this something I can put lock tite on bcuz it's really slipper and rotates easily? Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted July 24, 2015 Author Report Share Posted July 24, 2015 Check the adjuster on the pressure plate, also look at the pressure plate and verify that it is clocked properly. Also how do I clock the pressure plate? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 24, 2015 Report Share Posted July 24, 2015 Some say a dab of blue LOCTITE helps. I've never had a problem with out it. It can be a pain in the ass if you don't have a wrench that gets on and around the nut. Size the phillips screw driver really well because you don't want that stripping. The pressure plate is east. There is a dot on the hub and one on the plate. Line them up. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted July 24, 2015 Report Share Posted July 24, 2015 It was my clutch adjuster...is this something I can put lock tite on bcuz it's really slipper and rotates easily? You do have the jam nut on it? Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted July 24, 2015 Author Report Share Posted July 24, 2015 I'm pretty sure I do Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted July 24, 2015 Author Report Share Posted July 24, 2015 You do have the jam nut on it? I'm pretty sure I do unless there suppose to be another nut on the outside? Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted July 24, 2015 Report Share Posted July 24, 2015 There should be another nut. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted July 24, 2015 Report Share Posted July 24, 2015 http://www.google.com/imgres?imgurl=http://www.lcracing.co.uk/images/2013-12-22-nice-clutch.jpg&imgrefurl=http://www.lcracing.co.uk/page_21.php?pgenme%3Dwiblog&h=667&w=1000&tbnid=nbf-ajDIMTVjIM:&docid=zFkCSrmEfu4IeM&ei=l7ayVaKKKseF-gHe2JTADw&tbm=isch&ved=0CD0QMygVMBVqFQoTCOKxkJXj9MYCFceCPgodXiwF-A Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted July 24, 2015 Author Report Share Posted July 24, 2015 http://www.google.com/imgres?imgurl=http://www.lcracing.co.uk/images/2013-12-22-nice-clutch.jpg&imgrefurl=http://www.lcracing.co.uk/page_21.php?pgenme%3Dwiblog&h=667&w=1000&tbnid=nbf-ajDIMTVjIM:&docid=zFkCSrmEfu4IeM&ei=l7ayVaKKKseF-gHe2JTADw&tbm=isch&ved=0CD0QMygVMBVqFQoTCOKxkJXj9MYCFceCPgodXiwF-AWow that explains it thanks Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 24, 2015 Report Share Posted July 24, 2015 Well fuck it. Get a pancake bearing now. Your 6 bolts away from it. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted July 24, 2015 Report Share Posted July 24, 2015 Well fuck it. Get a pancake bearing now. Your 6 bolts away from it. 35.00 insurance Quote Link to comment Share on other sites More sharing options...
bluebanshee7 Posted July 25, 2015 Author Report Share Posted July 25, 2015 Well fuck it. Get a pancake bearing now. Your 6 bolts away from it. This one? Or will one off eBay be fine? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 25, 2015 Report Share Posted July 25, 2015 Site Sponsor AND Ebay... http://www.ebay.com/itm/Chariot-Clutch-Pusher-Pancake-Bearing-Yamaha-Banshee-Stock-aftermarket-clutch-/251956118125?hash=item3aa9c1426d&vxp=mtr Quote Link to comment Share on other sites More sharing options...
