You can raise the idle. It will in turn bring up the vacuum number. Set your idle where you like it and just make sure they are pulling the same vacuum.
  • Like 1
Make sure you're synced at about 1/4 and 1/2 throttle also. You can check by by making sure they lift off the bottom at the same time or by using the sync tool
