called up Noss machine to get some replacement domes for the shee. He hooked me up with no issue easy to talk to and really takes time to investigate your setup before he starts to cut the domes. 5 star service from this one. Wouldn't hesitate to order here guys.
I wonder if he just leaves a cnc set up just for domes. That way just loads or writes the appropriate programs and that's it. Carbide should last long since it's soft aluminum.
he doesn't that's one of the things he told me I only needed 1 blew the plug out of the head from too low octane And stripped the threads he said if he had to set it up it should just buy 2 domes.
He's right. You should buy a matching set.
He still cuts domes for almost all the builders.
He's pretty low key.
Tru Dat.
As said on here good domes for your setup makes or breaks your motor. It can detonate and kill it or stay cool and run for years. Domes are NOT something you should try to save $10 and buy on ebay.
  • 2 weeks later...
  • 1 month later...
Very satisfied with his fast friendly service. My head and domes were very nice and everything I expected. Directions for install were also detailed and easy to follow.
Sent from my SAMSUNG-SM-G920A using Tapatalk
