nightmarebanshee Posted July 22, 2015 Report Share Posted July 22, 2015 Rebuilding my bike newly ported cylinders dune/play port...has Vito cool head (believe it's hemi II) pro circuit exhaust and the trinity 2into1 35mm carb setup and im going to get some vforce 3 reeds...I'm going to have the crank welded and what not...my next questions are will that 35mm carb be enough with the new port or should I spend the extra money and go back to duals and what size if I stay with single or go to duals? I don't know much about the jet sizes for the single carb I assume I'll have to go up 2 or 3 sizes...and last question is are the pro circuits the right kind of pipe for my setup? From what I've read this bike seems to be set up for trails with single carb and pro circuits just kind of want to know what direction to lean toward thanks guys! Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted July 23, 2015 Report Share Posted July 23, 2015 Who ported them?What type of riding will you be doing? That will dictate carb and pipe selection. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 23, 2015 Report Share Posted July 23, 2015 Everything there is a decent package except that 2/1 intake. If you go back to even stock carbs, I bet you would see a bit of a gain bottom to top. You could probably even find another PWK for cheap and run duals and upgrade exhaust later down the road. If you must make it work, make sure you have an EEK needle. The mid range on 2/1 set ups can be a pain in the ass to tune and if you happen to currently have any DEG, DEK, CGL, CEL, etc. You are gonna be hard pressed to get it to run crisp. Start at 178 main Needle on middle clip 62 pilot Quote Link to comment Share on other sites More sharing options...
nightmarebanshee Posted July 23, 2015 Author Report Share Posted July 23, 2015 A friend that does his own porting on bikes and street cars did the porting he's done banshees before among other things looks really good comparing it to other similarly ported cylinders measurements and almost exact...and thanks for the carb advice I'm probably going to go back to duals eventually might even do it before I finish the build just gotta see what's in the budget thanks guys! Quote Link to comment Share on other sites More sharing options...
nightmarebanshee Posted July 23, 2015 Author Report Share Posted July 23, 2015 And I mostly ride fields back roads etc. Never really hit trails if I do its not for an extended amount of time Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 23, 2015 Report Share Posted July 23, 2015 Oh yeah, you're gonna wanna ditch that 2/1 for sure. You're gonna be mostly running Mid to Wide open for that kind of riding. If it were me, I'd put the 2/1 and pro circuits up for sale and see if you can save up the difference to go back to duals. For pipes, look for something like CPI's, Rockets, Shearers, or Snipers. Quote Link to comment Share on other sites More sharing options...
nightmarebanshee Posted July 23, 2015 Author Report Share Posted July 23, 2015 Yeah that's kind of what I was thinking do you think just stock carbs would be good or something bigger? Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted July 24, 2015 Report Share Posted July 24, 2015 that one 35 should pay for a couple stockers with the TORS kit installed and some change leftover Quote Link to comment Share on other sites More sharing options...
