Extended axle: really worth it?
I had a complete yfz spindle set up on the front with my +2+1 lsr arms. Requires about a 1/2 inch longer tie rod than usual and must be used with aftermarket arms with some type of adjustments or the camber will be way off. Then after you geto all this lined out and your stoked about your new aluminum spindles you will find out the tie rods hit the upper arm before reaching full lock left to right. I'm sure this could be worked out but don't expect it to just work
