Sounds like the right is running leaner than the left. Could be a lean carb,air leak on rightside, right rod bearing may be going out. Noticed my right pipe was running hotter than left, next day rod bearing went out. Might want to take those cylinders off and check things out before you run into a big problem like me.
Are you sure you got that choke tube connected in the proper spot...someone else reported they put it on the overflows instead of the choke holes....
are your carbs n'sync that can also cause your problem are your slides in correctly? the cut out part goes back. how are your spark plugs are both cylinders getting gas is one line clogged maybe?
yes there synced, i think the air screws are wrong cuz my friend touched the left 1 which is fine now and left the right 1 which is bad, or there mite be some dirt stuck in the carb
