Rear Carrier Suggestions
So I searched around a little bit and only found threads from about 2007 but the carrier I have on my stock swing arm now appears to be 3 pieces I will get pictures in the morning. There is play inbetween the bearing carrier itself and the 2 end brackets. it seems the aluminum is worn and there's no way to fix. I was told it was a durablue axle also not sure if this matters. But what carriers do you guys like for the stock style swinger? . Really trying to avoid getting into a 400$+ roundhouse setup right now.
