Straight Cut Gear Performance?
WALZ
Cool, thank you SheeRider for the picture that does add a perspective.  I hope I don't have to mount mine that high but I will try it before I knock it.  At least now I know what to be conscientious of as far as making sure the shifter is returning.  Appreciate everyones time.
Damn, that's high.
But my riding boot sits right under it in a neutral sitting position. When I lean back there's some pressure on it.
I can't see how people ride with them so low. I can't point my foot down way under the shifter in the middle of going through a set of whoops or hanging off the side through a trail.
You are for reals riding with your shifter that high???
Haha yes. That is the best position. My boot fits under the shifter with my foot flat on the peg and I lift just a little to down shift. To get my toe over top
My shifter is set at center of the stator cover. I generally either wear riding boots or steel toe work boots.
I rode Camatv's bike a few years back at LSOK. His shifter was so low I almost ripped my foot off after the bike wheelied and then came down. My foot was basically pointing at the ground.
I usually don't ride with my foot under the shifter.
Sent from my LG-D850 using Tapatalk
Me neither. But when I am riding it's easier to slide my foot straight under rather then point my whole leg down. I can't bend my ankle in riding boots.
Sounds like you need.to break in your boots some more..?
But aren't you mostly riding in a straight line and primarily up shifting 2-3 times and that's mostly it?
There's no freaking way I could ride even remotely aggressively and up shift and down shift correctly at that angle.
Try your shifter up like that. You'll like it. The boot is super stiff after a year. It's alpinestar tech 3. I can't bend my ankle at all. I'm pretty sure that's the way there supposed to be.
I've tried running my shifter at various positions. Running it that high is no bueno for me, not even close.
It's a pain in the ass for me to wiggle my size 13 riding boot under a low shifter.
My trails are 95% whoops. So I'm leaning back a lot. Toes are pointed up.
Amen^^^
I drug a toe ride before last because my shifter wasn't high enough.
Toes down = pain.
Toes up = out of the way.
Sent from my SM-G900R4 using Tapatalk
I can see this, especially with size 13s. I where 10s, I have short wide duck feet.
I need to be able shift gears in the rider forward or reward position when doing weight transfer maneuvers, so I have to find a happy medium for myself.
