special06shee Posted June 30, 2015 Report Share Posted June 30, 2015 No, homemade is all ya need. Here is a great write up. http://bansheehq.com/forums/index.php?/topic/110585-leakdown-tester/ Quote Link to comment Share on other sites More sharing options...
jeff n Posted June 30, 2015 Author Report Share Posted June 30, 2015 Cool thanks. Sent from my VS985 4G using Tapatalk Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 30, 2015 Report Share Posted June 30, 2015 I did things even simpler than that linc. I got pvc caps that fit boots, no pipe/glue BS. Got rubber caps that fit over ex, some use rubber end caps from stock bumper. First thing to do is test the tester, and around sparkplugs. Quote Link to comment Share on other sites More sharing options...
Burke Posted June 30, 2015 Report Share Posted June 30, 2015 Out the shop Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted June 30, 2015 Report Share Posted June 30, 2015 You are being told something other than the truth IMO. That plug is burned off from being lean .VERY LEAN. I have burned em off at the track or dunes from running bowls dry. It very well may not be the shops fault if you have a clogged carb jet, ran out of fuel while running hard in a higher year, clogged or pinched fuel line or other fuel delivery problem. Could even be jetting related or blown crank seal or something else. Or it could have been the fault of the engine assembler. That is up to you to find out and between you and him. That doesnt happen from chopping the throttle. Quote Link to comment Share on other sites More sharing options...
jeff n Posted June 30, 2015 Author Report Share Posted June 30, 2015 Thanks. I m going to do a leak down and will also check my carbs and fiel lines. Sent from my VS985 4G using Tapatalk Quote Link to comment Share on other sites More sharing options...
jeff n Posted June 30, 2015 Author Report Share Posted June 30, 2015 Will a leak down tell you if you have a bad crank seal? Sent from my VS985 4G using Tapatalk Quote Link to comment Share on other sites More sharing options...
camatv Posted July 1, 2015 Report Share Posted July 1, 2015 if you need a hand let me know i'm local to you. 2 Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted July 1, 2015 Report Share Posted July 1, 2015 ^^^^^^^^your best bet Quote Link to comment Share on other sites More sharing options...
jeff n Posted July 1, 2015 Author Report Share Posted July 1, 2015 I would love to find someone local. Can you send me a message or something with your contact info. Not sure what direction I'm going to go yet. Lots to consider but thinking about parting out both my bikes and building or having built a sick, like 7 mil 421 cub or something. If you have read any of my post or topics, it's obvious that I'm new to this but would love to learn more and meet more people but have had some BAD luck with shops so far. So please let me know how to get in touch with you camatv. Thanks. What part of the state are you in? Sent from my VS985 4G using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted July 1, 2015 Report Share Posted July 1, 2015 Can has been here a long time , I would trust his opinion Quote Link to comment Share on other sites More sharing options...
camatv Posted July 6, 2015 Report Share Posted July 6, 2015 in hutch about 50 miles west of wichita. i pm'd ya my number. Quote Link to comment Share on other sites More sharing options...
