Intake angle problem on my cub with UPP intakes
yes in the pics it is just touching, I have done it straight up and down and at a 45deg angle this is how far I had to adjust them so they would quit leaking out the over flow,  when they are set at 16mm the little bounce spring is just about bottomed out in the float needle. but I can not have them at 16mm because they leak, it is both of them not just one.
The picture of close up on the carbs the carb is tilted a tad so make sure your looking at it straight, Cody at fast said that does not look good.
