jscharphorn Posted June 27, 2015 Report Share Posted June 27, 2015 (edited) I have to set the floats at about 19.8mm for them to not leak gas out the over flow. ( 39pwk ) What are you guys using ? I seen a old post about wildcard ones are they still around and if so a contact # ? Edited June 27, 2015 by jscharphorn Quote Link to comment Share on other sites More sharing options...
Coupelx Posted June 27, 2015 Report Share Posted June 27, 2015 thats how they are on my cheetah. i think i did set them a bit tighter than spec but they work fine. are your float needles in good shape? Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted June 27, 2015 Author Report Share Posted June 27, 2015 Yes, these are brand new carbs Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 27, 2015 Report Share Posted June 27, 2015 Is there any other intakes that 3.8 mm from where they should be would worry me a lil , j don't have much experience with those engines Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 27, 2015 Report Share Posted June 27, 2015 They don't even look that terrible in the pics , huh. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 27, 2015 Report Share Posted June 27, 2015 How are you setting the floats. Tilting in an angle position till it just hit the spring on the needle lightly Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted June 27, 2015 Author Report Share Posted June 27, 2015 yes in the pics it is just touching, I have done it straight up and down and at a 45deg angle this is how far I had to adjust them so they would quit leaking out the over flow, when they are set at 16mm the little bounce spring is just about bottomed out in the float needle. but I can not have them at 16mm because they leak, it is both of them not just one. The picture of close up on the carbs the carb is tilted a tad so make sure your looking at it straight, Cody at fast said that does not look good. Quote Link to comment Share on other sites More sharing options...
