WEREhIeR Posted June 25, 2015 Author Report Posted June 25, 2015 Well idn about quality but I can steal the one from work tommorow and test with it. Quote
Strm Trpr Posted June 25, 2015 Report Posted June 25, 2015 Pull both plugs out. Make sure engine switch and fuel are off. Hold throttle WFO and kick it until the needle stops. For shits and giggles, I like to write down number of kicks and compression value. Rinse and repeat. Report back. Also, did you happen to see the condition of the reeds? You said they're VF3's correct? Kinda odd someone would put VF3's on a very stock motor. And I don't mean to sound like you don't know your way around a banshee, just trying to help, and hopefully other newbies can learn from this as well. Quote
Larry's Shee Posted June 25, 2015 Report Posted June 25, 2015 Don't let idle for long, may load up with fuel/foul plug plus no air mvement may overheat. Blip throttle to keep it cleaned out. Yes on O-rings in pipes, they need to seal well. I used some PVC caps that fit in the boots. Installed with 3bond and clamps. Don't really need crossover. Spooge coming out is from excess oil. May take a while to burn it out. Quote
WEREhIeR Posted June 25, 2015 Author Report Posted June 25, 2015 Stem trpr I did see the Reeds and they do look good but I may haveissued something the first time around. And don't worry... I don't know my way around a banshee very well... mostly just tinkered with 4 strokes mostly. Larry's shee I knew I needed the orings... guess I'll hAve to find some. .. are they special or?? And do I just put some plugs in the crossover tube holes or do they make different ones? Quote
Larry's Shee Posted June 25, 2015 Report Posted June 25, 2015 Don't know how "special" the O-rings are, but would imagine they'd have to be high heat. Maybe someone has a size they can post. Maybe take the pipe with you to auto parts or such, and with knowing outside dia. of the exhaust you could find something. Ya, you could order some from FMF (or anybody) but might be fall before it clears costoms, and cost ya 10x as much. As to the PVC caps, I just took a boot to the hardware store and found the best fitting piece I could. Was actually grey, might have been in the electrical conduit section. Leastwise here water lines are white and elec are grey. I should have cut them a bit for length for a cleaner look. I did this because the boost bottle was starting to crack the boots, not enough to need new, but still. Quote
WEREhIeR Posted June 25, 2015 Author Report Posted June 25, 2015 I got 95 psi on both cylinders tonight with both testers. .. I do have a new head gasket coming because that seems a little low no?? Quote
WEREhIeR Posted June 26, 2015 Author Report Posted June 26, 2015 Still a bad miss on the left side n spitting fuel... could I try changing jets from one carb to the other to see if maybe that's my problem? Quote
WEREhIeR Posted June 26, 2015 Author Report Posted June 26, 2015 Also he had vforce 3 reds in because he had it bored to the max I think .55 over Quote
sleeper06 Posted June 26, 2015 Report Posted June 26, 2015 I've seen vforce on tons of stock shit around here were the tips freyed and were they sealing good ( no light coming through) Quote
WEREhIeR Posted June 26, 2015 Author Report Posted June 26, 2015 Update! Moved the left slide to the right carb and the right slide to the left carb and no more bog! I believe he had the slides in backwards.... the flat side of the slide is to the front now.... has TONNNSSS of power... now I know why they call it a banshee hahahah but I still have more smoke from the left pipe and a slight misfire on that side as well... I have a new head gasket coming so hopfully that cures it... Quote
WEREhIeR Posted June 26, 2015 Author Report Posted June 26, 2015 And ya they're are sealing good with no light coming threw Quote
Larry's Shee Posted June 26, 2015 Report Posted June 26, 2015 Amazing, when all the parts are where and how they should be, fucking shit actually works Quote
sleeper06 Posted June 26, 2015 Report Posted June 26, 2015 The other day a kid came to me with a peice of a pen used as a carb top adjuster because original broke off during a cleaning. He couldn't understand why It didn't run rite. Then I get into the carbs just for a look see and find the float held in by a cotter pin . Needless to say it runs good now with all the rite parts Quote
WEREhIeR Posted June 26, 2015 Author Report Posted June 26, 2015 Hey just had one more question, Ive seen on other forums and such that you can take the coil wires out of the coil.. is that true? i have a spark tester i'm going to try tonight but the misfire doesnt seem to move when i switch wires from one to the other. What else could cause a random misfire? i did a leakdown test on the bottom end and it held 7 psi for 10 minutes so i dont think that is my problem. Quote
Strm Trpr Posted June 27, 2015 Report Posted June 27, 2015 What's your elevation? 95psi kicking compression is very low. Stock bore is 64mm. Max bore is 66mm. .5mm over is only .020" over, or 64.5mm. Quote
