splitting The cases..
We've talked this over before, but i have a froze push rod and need to split the cases. I have the motor out and ready, as well as a clymer repair manual, but where do I start? Do I have to pull the topend, cylinders etc? becuase ive heard that if you pull the topend the rings may not seat in again correctly.
Thanks!
Sad part is , you can still out ride me with only 1.5 hands.
Sent from my SM-G900R4 using Tapatalk
lol.
LS has been hard on me. Blew my knee out the first yr jumping off picnic tables, tylers motor ate my hand last yr, stay tuned to see whats in my future this yr.
  • Like 1
i have an impact, that should have enough torque then? illgive it a shot! anyone want to point me in the right direction though as to where to start? motor is upside down on workbench.. what all do i need to remove? bolts/parts wise
 Good place to start is with a manual.Tells the order bolts should be loosened/tightened. If you don't have a Clymers, should get one, or find the PDF on here.
