TurnerBanshee Posted June 23, 2015 Report Share Posted June 23, 2015 I would like use a more power light than stock yellow halogen without use a battery, I could buy 100W or 200W stator for use the stock headlight and 2 more lights like PIAA 005 xtream white or trailtech mr16 for help the stock lights I try iluminated a little more than only stock What stator watts is would works good for 4 halogen light all 35/35 watts because I try to search 40/40watts or 55/55 watts and I can't find this watts in this halogen system Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted June 23, 2015 Report Share Posted June 23, 2015 People have been using this with great sucess. http://www.ebay.com/itm/Universal-Snowmobile-Rectifier-Converts-12V-AC-to-12V-DC-Voltage-ATV-/171266352572?hash=item27e04525bc&vxp=mtr I plan on running one with my 10" Rigid LED Light Bar in the stock location. http://bansheehq.com/forums/index.php?/topic/180904-running-leds/?hl=led 1 Quote Link to comment Share on other sites More sharing options...
TurnerBanshee Posted June 23, 2015 Author Report Share Posted June 23, 2015 Where install this? Or how to install? I think that I take the yellow wire and put in a source that in the momment I turn on the shee send current? Ground any part of frame and red and black in the LED light? http://www.ebay.com/itm/Universal-Snowmobile-Rectifier-Converts-12V-AC-to-12V-DC-Voltage-ATV-/171266352572?hash=item27e04525bc&vxp=mtr&rmvSB=true Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted June 23, 2015 Report Share Posted June 23, 2015 You take the yellow wire from the stator and run it to the yellow wire on that rectifier. You put the brown wire to the chassis (as a ground). The stator is grounded to the engine which is grounded to the chassis already. Then you run the red wire from the rectifier to the positive wire on your lights. The black wire on the rectifier needs to be ran to the ground wire of the lights. Now, how would you recommend tapping into those wires? For instance, I'm going to run this exact rectifier. I have the stock plugs for the stock lights and the guy from Kompulsive Concepts wired in a custom hidden switch for my stock lights to come on high beam only. I want to use this switch, but it controls the two stock plugs. The 10" SR2 LED Light Bar has only 1 set of wires, what do I do? Quote Link to comment Share on other sites More sharing options...
TurnerBanshee Posted June 23, 2015 Author Report Share Posted June 23, 2015 Got it, 1- works led with rectifer and stock stator? 2- if I put 2 round or square leds in stock location I need 2 rectifers? Or just one? Quote Link to comment Share on other sites More sharing options...
TurnerBanshee Posted June 24, 2015 Author Report Share Posted June 24, 2015 1) LEDs will work on a stock stator and a DC rectifier. Might have a problem with flicker at idle, a small battery will cure this issue if you have it. 2) Does matter if you run 1 light or 100 lights on the same circuit, you only need one rectifier that support the power output of you stator. A stock stator with DC put out around 50-60watt (you lose some power when converting to DC). you can show which small battery could be please? Quote Link to comment Share on other sites More sharing options...
TurnerBanshee Posted June 24, 2015 Author Report Share Posted June 24, 2015 any battery you can find that is for 12V system. something like this http://www.ebay.com/itm/like/261417349131?lpid=82&chn=ps so if I need to put a battery for led flickers reason, the installation change, where wires put the battery? Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted June 25, 2015 Report Share Posted June 25, 2015 I used a relay in conjunction with the stock switch. My light bar is 125 watt LED. Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted June 25, 2015 Report Share Posted June 25, 2015 My stator is a250 watt rewound by sheerider1026. Used all stock wiring to control the relay. From the rectifier to the battery, from the battery to the relay, and from the relay to the lights I used #12 automotive wire. I have two small LEDs not going through a relay for low beam. Mounted a good sized gel battery under the seat. Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted June 25, 2015 Report Share Posted June 25, 2015 http://i1255.photobucket.com/albums/hh625/Russ_Knight/Mobile%20Uploads/0966B39C-7D85-434C-BA93-AA83098FF721_zpsav0omxvm.jpg Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted June 25, 2015 Report Share Posted June 25, 2015 Quote Link to comment Share on other sites More sharing options...
