it has been sitting for a little less than a week.. i was thinking that maybe my floats were stuck. Is that a possibility? I think im just goin to pull that carbs and give them a good cleaning maybe that wil help...anything else i should check?
Damn.....make sure the choke tube is in place, have you done anything to the shee since the last ride out??? maybe air cleaner got wet and froze??? possibly swapped the bowls on the carbs so the choke isn't working?? I need more info on what happened between rides.... :blink:
i havnt did anything to it. it was running just fine....then the kill switch stopped working. but i shut it off a couple of times after that and it started up just fine.but i really didnt let the motor get cold. I parked it in my yard and went out a couple hours later to put it upand it acted like it wasnt getting fuel. And fuel pours out of the over flows...the only thing that i did was put new plugs in it. And my air cleaner is fine..
try drain some gas out the drain screw in the boddom of the boul that will tell ya if theres gas down there and a lot of times it will clean out the carb and maby slove your prob
Is your tors still connected?? The tors will retard the timing or even miss every other fire...It'll act like its running on one cylinder but both are working...Sometimes they start and run shitty. Other times it wont' start at all....
my tors is dissconnected....i just took my bowls off and cleaned everything out with an air house and carb cleaner. They were clean....i pulled the choke out and it had dirt around it. I cleaned it up and kicked it bout 10 times to get the gas flowing.... i pulled the plugs and........................still dry as can be <_< . But fuel isnt pouring out of the over flow now....somebody what the hell is wrong??
I just bout new rear wheels and tires and i want to ride....grrrrr :angry:
It has to run..Spark and fuel = running... <_< Try pouring a little gas in the spark plug hole and see what happens. If it starts then its not getting fuel. If it doesn't then you have another problem....You can also check the reeds....
