New guy here. Looking for some answers.
But... But, the jet kit has to be right. It's a stage 3.
I was hesitant to even join a forum for this reason. I came for help. Not smart ass remarks man. I'm starting from 0 and thought I was doing right. If that's not the case, guide me vs just telling me it's shit
Sent from my SM-N910V using Tapatalk
Yfz shocks ride like poopoo. If all your trying to do is lower it some blaster shocks are much cheaper and ride like poo as well. Rm stators crap out, you can google that one and see multiple testimonials to their junkness.
First off welcome to Bansheehq.
Now let's see if we can save you some money and wasted time. Members can be a little abrasive at first but you will survive. You have found the most useful and knowledge
based forum on line. Simply list your current set up and future goals and the we will help you reach said goals.
Once again welcome
Troy
  • Like 1
I have seen a few of those cast plates crack and peices rattle around in the housing till it busts the pickuo coil. Mattoon makes a billet one. Make sure you use locktite!
The headgasket should be fine and ball joints you cant grease. Flush the fuel (prob already did..) and check wheel bearings and brakes. Once your jetting is good and clutch works right. You should be good...
This plate is machined, as I don't believe a lot in cast parts from other things I work on. Fuel tank and carbs were empty when I got it and fuel flows clean from the tank so I assume that's all okay. Brakes work great. Haven't checked bearings yet.
I guess the current setup will be
Stock internals
Stock carbs
Fmf sst stingers with power core 2 silencers
+4(?) timing advance
Ngk Iridium plugs
Individual filters
32:1 with 93 octane and yamalube 2r
Boyesen 2 stage reeds
Reed spacers
So based on that should I start with a 260? 270?
I like the iridium plugs once you get it jetted. they run forever it seems. Fantastic for a turbo car.
AS far as the timing plate it seems just recently the cast ones became an issue. Ive had one in my shitbox since like 07 or so and i bought it used.
As far as the yfz shocks they are too long for the banshee and rather stiff. a minor step up from stock. been there done that.
Now I'm getting some better feedback. I did grab 4 generic Ngk b8es plugs for chopping once I'm ready. I just personally prefer Iridium plugs in everything I own. I just wrapped up the timing plate set at +4, I'll try to get some jets tomorrow at one of the shops in town
i usually only put platinum / iridium plugs in stock vehicles you dont want to have to check the plugs for a long time.
on all my performance stuff, they get normal plugs.
ive had normal plugs last 40+hrs in the banshee, only reason i changed them was because i put another motor in it and wasnt going to use old plugs. they still looked good tho.
personal preference i guess.
 Gotta have thick skin around here. Shit don't get sugar coated, or made P.C.  Ricky Stator is shit. Quality challenged is the PC term I guess.
As to the lowering kit, more fucking shit. IF you actually read the description most all say not for jumping. Buy the right parts the first time. Buy once, cry once, save a ton of money, grief, and time.
