Degree key orientation
The key does NOT keep the flywheel from turning. The taper does. the key is to simply locate it properly. Want proof of this? Go pull the drive pully/clutch off a honda odyssey, no key.
You will want to install it so the flywheel is rotated counter- clockwise of its original position as you are facing it.
  • Like 1
