Darkblade Posted June 16, 2015 Report Posted June 16, 2015 hey i have a stage 3 port job with a cool head and 21 cc domes 65mm wiseco 795 pistons vf4 reeds uni pod filters fmf gnarly pipes with power core 2 silencers running a hot-rods 4mil long rod crank and stock carbs my areas temperature is between 75 and 95 degrees my elevation is between 600 and 850 ft what main jet and pilot jet size should i use and what should my needle jet be set on thanks Quote
Larry's Shee Posted June 16, 2015 Report Posted June 16, 2015 Plug chop or "read" your way to perfection. Quote
Darkblade Posted June 16, 2015 Author Report Posted June 16, 2015 30 pilot 340 main To start... thanks finally someone gave me an answer i appreciate it Quote
sleeper06 Posted June 16, 2015 Report Posted June 16, 2015 Might need a bigger pilot if it's not cracking at idle and sounds dull Quote
