Jetting
hey i have a stage 3 port job with a cool head and 21 cc domes 65mm wiseco 795 pistons vf4 reeds uni pod filters fmf gnarly pipes with power core 2 silencers runnin a hotrods 4mil long rod crank and stock carbs my areas temperature is imbetween 75 and 95 degrees my elevation is between 600 and 850 ft what main jet and pilot jet size should i use and what should my needle jet be set on thanks
Stick crank with wisco 65 and fmf pipes what should i jet my carbs at
Sent from my SPH-L600 using Tapatalk
 whats your temp out side and your elevation
 Good question :rotflmao:
Darkblade hyjacks thread asking for jetting advice, then gives advice without enough info from mike, such as "what filter set-up Mike?"
only reason i gave advice is because i had the same setup and im new to the banshee forum and every time i ask the same fucking question trying to get help and people will just not reply or talk some fucking shit about how im on someones thread i only did that because i figured that that  was the quickest way to get an answer so sorry for asking for help
. <<<<<< here , you can have that one free.
Sent from my SM-G900R4 using Tapatalk
