From 20cc to 19cc stock bottom end
I have a 01 banshee all stock as far as cylinders and bottom but I have +4 timing , stealth head 20cc domes, pipes and a set of vforces. My question is could I run 19cc domes with pump fuel with an elevation of 175ft is that's correct(Virginia) and would the stock bottom end hold up with that extra compression from the 19cc domes??
400'asl is cutting it close with that setup on pump.  Mine has started to show a few pits with 21cc domes, +4, and pump gas @145'asl.
I'm with Zilla.  Have the crank trued and welded, then have the cylinders ported.
  • Like 1
