Rapture Posted June 14, 2015 Report Share Posted June 14, 2015 Just want your opinions on this... Have rebuilt the rear caliper with new pads and bled the system about 4 times. 3 times with a vacuum pump (similar to mityvac) and reverse bled them. Im 99.9% sure theres no air in the lines. However, the pedal travel is ridiculous. All the sliders are free and lubed, no leaks, but i have noticed the caliper "rocks" slightly when the pads have made contact. Any ideas? https://www.youtube.com/watch?v=qyh89mO02BY&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted June 15, 2015 Report Share Posted June 15, 2015 pull that excess line down instead of looped up like that and bleed it again Quote Link to comment Share on other sites More sharing options...
Sandking Posted June 15, 2015 Report Share Posted June 15, 2015 There's probably air in the master cylinder. Unbolt it, flip it upside down and remove snap ring at the bottom. When fluid starts to escape put it back together and bleed it. Quote Link to comment Share on other sites More sharing options...
toytech Posted June 15, 2015 Report Share Posted June 15, 2015 if you unbolt the caliper put an extra pad in it and hold it up higher then the master it will bleed out better. Quote Link to comment Share on other sites More sharing options...
Rapture Posted June 17, 2015 Author Report Share Posted June 17, 2015 Tried all of these and its still crap. The rod coming from the MC moves about 10mm before theres even any resistance. Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted June 17, 2015 Report Share Posted June 17, 2015 Haha looks like u got dog shit on the tip of ur shoe lmao Quote Link to comment Share on other sites More sharing options...
Rapture Posted June 17, 2015 Author Report Share Posted June 17, 2015 Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted June 17, 2015 Report Share Posted June 17, 2015 crimp the line close to the master with a g-clamp, if it still spongey like that youve snagged an o-ring or something Quote Link to comment Share on other sites More sharing options...
Rapture Posted June 18, 2015 Author Report Share Posted June 18, 2015 Clamped the line and the MC is rock hard. I think its something to do with the new pads not pressing on the disc squarely, so the caliper is flexing on the slides to compensate. Hopefully the pads will just wear to the angle of the disc in time. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted June 18, 2015 Report Share Posted June 18, 2015 Is the caliper "floating" on the pins freely? Quote Link to comment Share on other sites More sharing options...
Rapture Posted June 19, 2015 Author Report Share Posted June 19, 2015 Yeah all free and lubed. Perhaps they are just worn. Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted June 19, 2015 Report Share Posted June 19, 2015 Theres air somewhere in the system Quote Link to comment Share on other sites More sharing options...
