badboy95 Posted June 11, 2015 Report Share Posted June 11, 2015 Took my top end apart to find Blaster pistons, they say 573m06700. Cylinders may need to be cleaned up....maybe a re-hone? What do you guys recommend? It still has the stock sleeve i am not sure what the maximum is on this. What can happen if it is run this way? Quote Link to comment Share on other sites More sharing options...
badboy95 Posted June 11, 2015 Author Report Share Posted June 11, 2015 I am not sure if it is a stock sleeve or not i just assumed it was...but it is a blaster piston and is a 67 mm piston. It looks like the walls might be getting thin. So is it not possible to bore a stock cylinder that far? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 11, 2015 Report Share Posted June 11, 2015 I got a set of unported cylinders at 64.5 if you want to go back down to a stock piston. Quote Link to comment Share on other sites More sharing options...
