Roo-ease Posted June 10, 2015 Report Share Posted June 10, 2015 Back in May I bought a banshee of a guy on craigslist and I was aware of the mods he told me he made (simple bolt on). after running it I found it had some issues and posted a question about jetting thinking it was the issue. After doing a leak down and compression test, it only failed the compression test. I decided to do a top end rebuild and found some things the guy didn't mention as i took it apart. it has: Toomey T6's Noss performance cool head with 19 cc domes 28 mm Mikuni carbs main jets 295 with uni filters no airbox then I came across the Hot Rod crank (H.R. 204/ C.K.158 with 115mm rods so im assuming long rods) i wasn't aware of...I tried to get a hold of the guy to ask some more questions, what he was going for to get an idea of what I need to buy for the rebuild but he never returned my calls or texts so my questions are: what was he going for? how many cc's does the banshee sit at? does anything sound wrong with the set up i need to correct? what pistons should i get and how to tell which pistons are for long rods and short rod? sorry for all the questions i just want to do it right..thanks in advance Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 10, 2015 Report Share Posted June 10, 2015 If it was me I'd pull it all the way down. Inspect everything, take good pics, post them here and then listen to what the people who know what they are talking about guide you. If there is nothing wrong in the bottom end it cost you 19 bucks for sealant and 13.99 for a case of beer while you do it. If there is something wrong it saves you thousands in parts and hundreds in beer. 2 Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted June 10, 2015 Report Share Posted June 10, 2015 I thought mikuni jets went by 10's like 280, 290, 300? 1 Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 10, 2015 Report Share Posted June 10, 2015 If it was me I'd pull it all the way down. Inspect everything, take good pics, post them here and then listen to what the people who know what they are talking about guide you. If there is nothing wrong in the bottom end it cost you 19 bucks for sealant and 13.99 for a case of beer while you do it. If there is something wrong it saves you thousands in parts and hundreds in beer. I agree! Good advice from the CEO of GMI. Quote Link to comment Share on other sites More sharing options...
Roo-ease Posted June 10, 2015 Author Report Share Posted June 10, 2015 (edited) Thanks you guys. I'm in the process of a complete break down when I come across some free time..so far I just came across everything I mentioned..I wasn't aware that mikuni jets came in increments of 10 but as soon as I figure out how to resize a picture I will begin posting pictures. It keeps saying files are too big to upload. Edited June 10, 2015 by Roo-ease Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 10, 2015 Report Share Posted June 10, 2015 Use photo bucket or tapatalk Quote Link to comment Share on other sites More sharing options...
Roo-ease Posted June 11, 2015 Author Report Share Posted June 11, 2015 so here is a pic of what has causing the compression issues and thanks for the suggestion for tapatalk it worked easily Sent from my SAMSUNG-SGH-I337 using Tapatalk Quote Link to comment Share on other sites More sharing options...
98_sheester Posted June 11, 2015 Report Share Posted June 11, 2015 Ouch lol piston is beat but ive seen way worse Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 11, 2015 Report Share Posted June 11, 2015 Any clue what brand those pistons are? Look to see if the ring locater pin is still in the piston. Looks like a fresh bore is in your future. Quote Link to comment Share on other sites More sharing options...
Roo-ease Posted June 13, 2015 Author Report Share Posted June 13, 2015 No idea what the brand those pistons are I'm assuming still oem they are 64mm pistons and the top of the pistons are completely charred and have a strange dimple/pit i have never seen been done to a piston..the pins are still in just too far in to where they are serving their purpose. .yeah fresh bore coming up..yeah probably the reason why the guy never returned my calls Sent from my SAMSUNG-SGH-I337 using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted June 13, 2015 Report Share Posted June 13, 2015 That pit is where it melted from a lean condition. Quote Link to comment Share on other sites More sharing options...
Roo-ease Posted June 13, 2015 Author Report Share Posted June 13, 2015 I figured but I wasn't 100% sure... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 13, 2015 Report Share Posted June 13, 2015 to bad it needs a bore. Could make hella deal on some 64s someone stuck in 64.5 holes, No carbon on one piston, very little on other. Hey, what the fuck ya xpect for a $600 wonder. Quote Link to comment Share on other sites More sharing options...
Roo-ease Posted June 14, 2015 Author Report Share Posted June 14, 2015 Haha yeah that's true..earlier I said I thought the pistons were stock but after scraping away the carbon build up on the left piston I came across the numbers on the top 795M06450..so I got that they are 795 series for a long rod crank is the 6450 part mean the piston is actually a 64.50 mm because my caliper is showing a straight 64.00 they aren't the best calipers but what do you guys think? Sent from my SAMSUNG-SGH-I337 using Tapatalk Quote Link to comment Share on other sites More sharing options...
m671054 Posted June 14, 2015 Report Share Posted June 14, 2015 Throw that ruler away and het a real set of calipers. Pistons are 64.50 Quote Link to comment Share on other sites More sharing options...
