Stevenhaines02 Posted June 5, 2015 Report Share Posted June 5, 2015 Bought a complete gasket/seal/bearing kit .my bearings dont have the locator dowels or orings on the outter races. TZ and maxload bearings. How are you guys installing these, without them spinning in the cases? Thanks Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted June 5, 2015 Report Share Posted June 5, 2015 Is there no clip groove on the pto side and stator side, where did you get it Quote Link to comment Share on other sites More sharing options...
Stevenhaines02 Posted June 5, 2015 Author Report Share Posted June 5, 2015 They are TZ and maxloads that came in a bottom end rebuild kit put together by a seller, they just dont have the locator pins in the outter race like oem bearings. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted June 5, 2015 Report Share Posted June 5, 2015 Locator pins aren't needed. And have caused me problems a few times. Those pins will fall out, or outer race will turn while trying to install crank, and the pin ends up smashing into the case. I use bearing locktite on them, though not sure it's necessary. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 5, 2015 Report Share Posted June 5, 2015 if outter TZ has no clip.. the crank has a chance to walk for sure.. been there.. Case crush will not keep the crank in place. Quote Link to comment Share on other sites More sharing options...
Stevenhaines02 Posted June 5, 2015 Author Report Share Posted June 5, 2015 TZ has full clip, only thing different is the lack of pins that are on oem bearings... I appreciate the help guys. Used the search and couldnt find much pertaining to the locator pins. Thanks again. Quote Link to comment Share on other sites More sharing options...
