complete suspension setup
justsmith94
My current suspension setup just doesnt seem to be working out to well. So please help me out here. Im new to atvs let alone suspension.
Right now i have +2+1 a arms up front with yfz 450 shocks.
The rear is stock swingarm with a 4" extension, stock shock, and rims flipped around to make it wider.
I Run holeshot xct tires, 22" rear, 23" fronts.
I need the added clearance because here in PA, where im at, 75% of the trails are rocky and washed out.
Any suggestions on what to do to make the quad not so nose heavy and handle a little better?
I think im going to get a new set of elka dual rate shocks. They seem to be a favorite around this forum. Its only a trail bike so i shouldnt need anything too fancy.
Who can i send my rear shock to to be rebuilt? I would like to have a it done and back to me as soon as possible.
Also, would i be able to run such big tires with a -1 or so swingarm?
Do you have the power and need for the +4 swingarm?
If not, look into a stock length round house carrier swingarm.
If you have the money, just buy a complete set of elka stage 3 for around a grand. They will be set up for you and your quad. Correctly setup shocks, even cheap ones, will be better than incorrectly setup high end ones.
I dont think i need the plus +4. It has dune port, t5 pipes, +4 timing, vforce 4 reeds and thats about it. It just spins everywhere i go.
Wheres a good place to order the shocks?
Im going to order the elka stage 3 set like zillafreak recommended, tonight. Im also going to order another chain and get 13 and 14 front sprockets and a few different rear sprockets. And take the 4" extension out of my swingarm to see if its any better. If i like how it is, i will try to find a round style swingarm.
Any suggestions on steering stems and bars?
