jscharphorn Posted June 26, 2015 Author Report Share Posted June 26, 2015 Well now I have another issue, the 39pwk carbs and UPP intakes I purchased my angle seems high and I have to set the floats at about 19.8mm for them to not leak gas out the over flow Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted June 29, 2015 Author Report Share Posted June 29, 2015 were did you get the intake ? Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted June 30, 2015 Report Share Posted June 30, 2015 Just set the float level lower until it stops overflowing. On gas unless you are going to run 1/8th mile it should still be good with a dual pingle and good fuel line. I have had no problem with upps and floats set lower. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted June 30, 2015 Author Report Share Posted June 30, 2015 Thanks guys. I ordered billet bowls to make sure I have enough fuel. Quote Link to comment Share on other sites More sharing options...
camatv Posted July 1, 2015 Report Share Posted July 1, 2015 bogs with dirt tires? yikes Quote Link to comment Share on other sites More sharing options...
dozer Posted July 1, 2015 Report Share Posted July 1, 2015 when your adjusting the float, did you check the float height where it just touched the needle or when it was actually pressing it closed? Quote Link to comment Share on other sites More sharing options...
camatv Posted July 1, 2015 Report Share Posted July 1, 2015 are those upp intakes? i just read all the stuff on the dome dome is fucked. just stop and get the right dome now. if you havent already./ 1 Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted July 1, 2015 Author Report Share Posted July 1, 2015 With the different carbs I now have the hole shot. Yes floats set just touching, in the pic that is were it needs to be so it does not over flow. Quote Link to comment Share on other sites More sharing options...
theputz Posted July 1, 2015 Report Share Posted July 1, 2015 I had the same problem with my pwks and upp intakes. To much of an angle. I lowered the float height 2mm and bent the overflow tube upright. Saw this on a ktm site I believe. Quote Link to comment Share on other sites More sharing options...
